Thanks all. I looked under today and I think figured out what the oil is from. It looks like its coming from my differentail or axle from the front. Looks like a seal or something there right on the back, and in the middle of the axle.
Also, my pto control shaft does not spring back. the rubber around the shaft is ripped and catches some but I just bump it and it springs down to center.
So.. It still will barely just pick my front wheels up, and I have a leak in the front Diff.
I am more concerned with the power loss and thoughts. Any idea on the seal, or is that white cap looking thing something else. lol
That takes 80/90 weight right?
The front axle can take gear oil. Others, including the factory, use HST oil. I prefer gear oil.
Photos may help explain the seal/white cap thing.
I think we need to clear up the "PTO control shaft" thing. PTO controls are the smaller lever that has several stops as well as gear icons. It is used to activate the MMM and PTO shaft that come out of the rear of the tractor. That lever is on the left side of the tractor.
The 3 PH lever is the large one on the right side that has a long throw and raises and lowers the 3 PH (along with your box blade). It should always be in the middle when done lifting and/or lowering.
To check the FEL, put the bucket on something large and level - like a stump that is slightly above ground level. And BE CAREFUL.
>Set the engine RPM to full (WOT) and move the joystick to power down the bucket (lever forward but not all the way to float). That should lift the front end of the tractor - don't go more than a few inches.
>Then set the tractor back down by lifting the bucket.
>Next curl the bucket downwards (dump, or lever to the right). That should also raise the tractor's front end. Once again, only go a few inches.
If it can't do that then there may be a problem with the hydraulics. But since you said it was fine when you first bought it then there is likely another issue somewhere.
Does the 3 PH struggle to lift the box blade?
As I recall you tested the FEL with the BH on. The issue arose when the BH was taken off. Putting the BH back on and trying again may bring some enlightenment.
The installation of a BH on some tractors involves a diverter valve that has to be opened/closed to operate the BH. It greatly affects the use of the hydraulic pump. If the valve exists and is in the wrong position then you have your answer (let's hope for a simple fix)! OR...you may need to connect the input/output valves that the BH's hydraulic hoses fit into to get a complete circuit of flowing hydraulic oil.
However, the BH may be driven off of the PTO and have its own pump. That should not affect the tractor's hydraulic performance.
I don't have a BH on my BX so someone else will have to chime in on that one. Maybe the dealer would know.
Sorry, I seem to have raised more questions than I answered.
