BX22 with BT600 backhoe
jacky Box
BX22
Jun 13, 2016
Salisbury, NC United States
I busted one of the lines to the BT600 backhoe. I had both lines going to the backhoe made at a auto parts dealer (line busted Sunday morning) and replaced them both. Now I have no power to the backhoe. When I disconnect the line from backhoe no fluid is in the line. :confused:
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
356
88
Canton, MS
With tractor shut off word all levers on bh to relieve pressure, CHeck your quick connects and make sure the line you had made are clear.
3,261
Disconnect the BH (take it out of the loop) and reconnect for 3PH only. Do the lift arms of the 3PH work? make sure you close the loop before trying the 3ph.
Did you re-use the original fittings on the new line? If not, maybe the fittings are slightly different/stuck or not seated properly.
