BX 25D Tachometer
willkraft
BX25D
Oct 19, 2014
Forest Hill
My tach is not working, not sure if its the alternator or the display panel? I am have a hard time removing the steering wheel. Any advise will be appreciated.
4,601
Make sure the altenator is charging. If it's not charging the tach won't recieve a pulse count.
Check your fuses, and the connections at the altenator for the smaller wires. Some times it's as simple as a spade not making good connection on the altenator. Simply wiggling the wires at the altenator could fix it temporarily. If thats the case it will show you where to look and check.
If you rule out the altenator side or fuse issue, then it's probably on the tach side. Could be an issue with the power, ground, or sending wire going to it.
If it's still under warranty, having the dealer take care of it, is an option as well
willkraft
BX25D
Oct 19, 2014
Forest Hill
I don't think it is mice, I pretty much know how it happened. I checked the fuses several times, checked all wires,cables and connectors. I am getting a low voltage from the alt. so I'm pretty much sure its in the display panel. But I cant figure out how to get the steering wheel off. The WSM says take off the nut and then take off the steering wheel. But is not coming off.
