Best tires for snow?
2,190
I cant either, but thats seems to be the census. My R4 industrial tires did excellent last year in the snow. I was using the FEL and a rear blade, moving forward. Now with a front snow blower on the way and a clean path, I think any tire will work. :D
I am with you SLIM, my R4's worked great moving snow last year, I am sure I had some wheel spin, but never felt it, never remotely got stuck, but I was on level ground. I have had all 4 tires (3) spin before, mud - nice wet mud, but turfs would have spun quicker!
2,190
Anyone using a tire tool to add grooves or sipes to R4's?
To sipe the tires would probably cost more than chains! If chains were not a method to consider, then "spiking" the tires would be a way to go. Screw in studs can be a way to go if hard surfaces are never seen!:D
Garandman
L3200, SSQA bucket, pallet forks, Ratchet Rake, Wallenstein BX42s chipper
Sep 1, 2014
19
Boston / Sullivan County NH
Many, many people have done on the "other" forum. Seems to take 40 minutes to two hours.
olthumpa
L275
May 25, 2011
1,501
Maine
When you discribe which tires and how the work, what are you refering to:
Plowing/cleaning a driveway-
Plowing/cleaning a section of field-
Crossing an uncleared field-
Working in the woods-
Etc -
BAP
Dec 31, 2012
2,534
672
With the price of tires now a days, I am not sure why you would cut up your tires for a possible little gain in traction. Siping is not going to help you on ice so when you have some under your snow, you still will be up the creek without a paddle. Best bet is a good set of chains and learn how to put them on and off.
OBKubota
2014Gr2120,Gr2728Snowblower,Gck5GrassCatcher,agri-FabSpreader
Oct 21, 2014
205
Ontario
I have new Gr2120 awd with turf tires and snowblower on front, the dealer said I wouldn't need chains or different tires or weights. My driveway is 100 ft and paved with a bit of uphill grade. I will update when we get some snow.
