Best approach to convert OEM LA-524 pin on bucket to QA ??
wendol
L3800 HST
Feb 5, 2014
191
37
North Tx
I have ordered the L2216 "2-lever Quick Coupler" from my local Kubota dealer, and now trying to determine best way to convert my existing bucket.
#1:
I see all types of Quick Attach Plates (weld on) available in different designs, and thickness and since my bucket has a type of V shape reinforcement between my pin on brackets, wasn't sure what style/design is best.
#2:
Are the bucket stops effected with this type of conversion?
All thoughts, suggestions, recommendations are appreciated!!!
5,128
If you can cut off all the original mounts and put a plate on it, use a 1/4" or 5/16" plate.
Bucket stops will be in the QA mount.
1970cs
1,124
Grand Ledge
Or buy one of these from HLA/horst manufacturing.
As above cut off your pin gussets and weld on one of the top row units in place.
Pat
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
cut the mounts and brace off of your bucket to make a flat surface and weld on a ssqa plate.
