B7100HST Filter Screen
Brewbek
B7100HST
Mar 26, 2017
NE Ohio
I'm changing hydraulic fluid and having trouble locating the filter screen. All other drain points have been marked with the red paint. Apparently the screen is not. Could this be it as shown in the pic.? Location is to the right of the seat as viewed from the rear of the tractor. Looks like the fender may need to be removed to access this but the cast housing that this fits in feels like the screen would fit there.
Any help suggestions would be appreciated. Hopefully my pic loads, I am pointing to it with the pointer. Thanks. Jim...
[/URL][/IMG]
5,152
Yes, that's it, normally you just need to pull the tire. ;)
Brewbek
B7100HST
Mar 26, 2017
NE Ohio
Thanks Wolfman! Good to hear only the tire needs to come off even though the fender isn't that big of a deal. Thanks again! :p
Brewbek
B7100HST
Mar 26, 2017
NE Ohio
I found the screen, how do I clean it. It really does not look dirty at all. I wiped the outside to get the fluid off and when I hold it up to the light I can see through it. Really don't think it's bad at all. Any advice?
2,180
Id say you got her clean enough - most use a solvent that will evaporate easily.
IF it looks clean - it probably clean enough. It only catches good size particles.
Mostly metal shavings.;):)
Brewbek
B7100HST
Mar 26, 2017
NE Ohio
Thank you 85Hokie. I put it back together and I too think I'm fine.
