B7100 - lubricate central pin and lower King pin
riddle2
B7100
May 26, 2017
14
Schweinfurt, Germany
Hi Guys,
I really need your fast help.
I bought a Kubota B7100 and I wanted to lubricate the grease nipples.
But I can't find the grease nipples for the central pin and also not for the lower King pins.
Is anyone able to help me?
I don't want to "injure" my tractor by driving with no grease.
Thank you in advance.
riddle2
5,185
Is it a 2wd or 4wd?
If it's a 2wd the grease zerks should be, left side front on the pin, and rear center on the king pins.
If it's a 4wd there is none as it's done via the oil in the case.
riddle2
B7100
May 26, 2017
14
It's a 4wd.
So if I have a 4wd, I have no grease nipples for the central pin and no grease nipples for the lower King pins?
Best Regards,
Tom
4,074
Don't believe there is one. All oil is in the wheel gear case for the FWD.
Just make sure that the front axle has the oil changed periodically, which includes draining the wheel gear case at each front wheel.
If you go here:
http://www.kubota.com/part/partsList.aspx
Agree to the terms, type in your model number, and go to front axle, you can find an exploded diagram of the wheel case. I just looked at it.
2,240
The pivot pin is splash lubricated by the front differential oil.
