B7100 HST 3 point Blade Size
2,926
Im gussin that you wouldnt want to go much wider than the rear wheels, but thats just a guess on my part
B7100hst-d
53
NLR AR
B7100hst-d w/turf tires, and approx 100lbs on (f) bumper, and can mount/run 5' blade on 3pt with no difficulty, but once the pushed load gets very heavy/much, it gets worse.
I usually attach my 4' box blade and am much happier with the performance
traildust
B7610HST 4WD, LA352 FEL, Gearmore 2 Spool Top & Tilt Box Scraper
Jan 27, 2010
1,490
Phelan, California
Stay within reasonable limits of the tractor and you will never be disappointed.
B7100hst-d
53
NLR AR
FWIW: Operators Manual shows rear blade width of up to 60" and 350lbs is good to go.
Box blade: 42" ~ 380lbs (although I run a 48" that only weighs around 100lbs or so and add another 125lbs or so to it with zero difficulty)
evan4434
B7100 HST
Mar 19, 2010
Kellogg,IA,USA
I ended up getting a 5 foot rear grader blade. It weights 250 lbs, and seems to work pretty good. I have a FEL as well, so this really helps even the weight out. We will see how it does in the snow.
