B7100 - Excessive Smoking
Marndin
B7100
Jun 3, 2017
9
UK
My B7100 smokes a lot. Does anyone have any suggestions on a quick fix. I seem to remember years ago that there was a substance that you can put into the cylinders that help the pistons seal more?
Here's a link to a video showing the smoke it's much worse under load. There's also smoke comming out of the vent on top of the rocker cover.
Any comments & advice greatfully received - https://youtu.be/7ixWzzCzgUo
Thanks in advance
Martin
JerryC999
B7100HST
Aug 16, 2014
89
Simpsonville, KY
Hmm, if that is excessive smoke, then I have a problem as well. You are talking only about bypass smoke, and not any exhaust smoke, correct?
Does it have adequate power?
Marndin
B7100
Jun 3, 2017
9
UK
It has good power, but when under stress smokes badly. The biggest thing I ommited was that it looses water and overheats.
Many thanks
Martin
5,122
Blown head gasket or cracked head.
And no there is no magic oil or fluid to fix it, it simply needs taken apart and rebuilt. ;)
2,170
I would agree with wolfman,coolant loos is bad enough and repeatedly overheating is just destroying the engine.
I too 3rd that notion.......and running it as is....will cost more to fix!
murky
107
Vancouver, WA
My B8200 smoked like that. It had a crack in the head. I bought a rebuilt one and had it installed by a Craigslist mechanic. Then did my own valve adjustment which apparently he overlooked.
