B7100 D fan belt replacement.
hutch36m
B7100
Sep 16, 2018
HOWELL
I have a kubota b7100d and need to replace the fan belt. Read the posts on the HST model but mine is different in terms of where the PTO shaft off the crank comes into play. How does one get the shaft off to get your belt on from the bottom? I understand getting around shrouds etc but not sure how to tackle on the front end.
Thanks.
Work Horse
B7200 HST 4x4
Jan 21, 2020
121
IPSWICH
Thanks.
I'm not familiar with what your referring to with the PTO shaft... Unless there's something really funky going on it should be pretty easy.. just did mine yesterday on a 7200HST. I believe the easiest (maybe only) method is to remove the radiator. Gives you direct access.
