Bought a B7000 from a guy that said hadn't run in years. I put a new radiator, hoses, belt, tensioner pulley bearing, rebuilt the rusted out rims, new tires, changed hyd. fluid, cleaned hyd. filter. Runs great and all hydraulics are working. The tilt/dump option of the bucket is my last fix. I can move it through it's range, scoop through dump. If left in the full up (scooped) position, once I let go of the lever it will slowly drift to dump. I see no leaks and hyd. fluid is full. All.other hyd. features work properly. Need some help on what to check to get the bucket working properly. Thanks!
