b6200d backhoe subframe/hydraulics question
seant
b6200hst
Apr 18, 2016
23
Morgan Hill, CA
Hi All,
I've gotten so much out of this forum. Thanks in advance:)
I recently purchased a chinese bh5600 3 point mount backhoe. It works well enough though may be a tiny bit too big to mount on my b6200 three point.
I'm going to build a subframe mount for it and have a couple questions.
1) Do you think channel steel or rectangular tube would be best for the frame? What size?
2) WRT the hydraulics: It came with a PTO pump which I'd like to not use. I think the b6200 should have enough oomph in it's hydraulic system to run the BH and I'd like to move the BH closer to the rear of the tractor. I'm a little concerned about how much fluid it will use and take out of the system when hooked up. Do I need to add take that into account somehow?
3) Where is the best spot to tap into the hydraulic line? I think there is a factory kit that replaces part of the 3 point life with an outlet. Would that work instead of cutting the existing lines?
http://www.colemanequip.com/Kubota-...TEM-33693/HYDRAULIC-OUTLET-OPTION-33732/?&o=1
Thanks in advance.
Sean
8,647
The on board Hydraulic pump On a B6200 will not run that BH effectively if at all, you need to stay with the PTO pump.
