B6200 engine in a b7100
Garrettl1515
B1750 B2150 L3350DT L345DT B7100HST B7100 L2201 B6200
Feb 19, 2024
39
21
Bakersfield CA
Have the chance to buy a b7100 very nice with loader but no engine. Also can buy a b6200 with running engine but 2nd no loader. Will the motor in the b6200 a (850) fit in the 7100 (750) any advice helps
5,329
Yes, the external block size is the same and mounts are all the same along with flywheel mount.
You just might run into a slight twist.
1/2 of the b6200's were a thermosiphon system, and the other 1/2 were a water pump and thermostat system.
Both will work but if you have a choice you want the Water pump version.
I can tell you how to alter the radiator very easily to fit the water pump or you might be able to use the B6200 radiator.
Garrettl1515
Feb 19, 2024
39
21
Bakersfield CA
Thanks for the fast reply I’ll keep you updated, would the loader from the 7100 fit a b200
5,329
That would depend on the loader, some did cross over.
Looks like the B7100 is a 4wd where the b6200 is a 2wd.
4wd's make much better loader tractors.
