B6100D Hard Starting?
clippy
Kubota B6100D w/ Kubota FL1000 Tiller, Kubota Bedder, Brush Hog Mower
Hi everyone. I've read on here about hard starting. I'm pretty new to tractors and I'm not exactly sure what qualifies as hard starting. So I figured I would post a video and ask for some feedback. I sure know that my little B6100D is harder to start this winter compared to last summer (when I bought the thing.)
Here's the link to the video on youtube: http://youtu.be/ClA-M3r8ZUo
Just to let you know, it was the first time I started the tractor in 3 or 4 days. Those nights were getting down to -12 or -15 celsius (5 - 10f) and not warming up much during the day time. I switched the glow plugs on for about a minute prior to trying to start the first time. I then paused the recording at about the 15 sec mark while I switched on the glow plugs for another 30 secs or so.
(Sorry for the poor lighting... a window in the shed is basically directly in front of the tractor.)
Thanks.
4,708
Your alright if it's just glow plugs and below freezing ;)That actually did pretty darn good. Mine needs the starter and altenator sent in for rebuilds, so it's not putting a charge on the battery like it should. Only putting out 13 volts. And you have to pull the decompression lever even with a set of jumper cables on it to get the starter wound up enough to get the motor to fire :rolleyes: Starters got a bearing dragging.
So if mine started as quick as yours under those temps, I would be a very happy person :D
2,210
clippy, your machine is starting FINE! You need to find something else to push your "worry" button.:)
I would say you have that "problem" solved.......at that cold temp - it takes me a lot more than a 30 second glow plug to get me running!:eek::D:)
really - your tractor is in goooood shape!:)
5,278
Yea like everyone is saying, That starts better than when it was new!:eek:
2,241
Yep, looks fine to me. Something many are not aware of is that you can hit the glow plugs again after it starts- smooths it out quicker on those cold mornings. About 10 seconds is usually enough to make a big difference in mine.
ShaunBlake
Dec 21, 2014
899
huh! Now that's counter-intuitive, and I doubt I would have *ever* thought of it. I should be able to try it out this week since we're due for another couple of days of cold before the wet comes.
4,708
I never thought of glow plugging after either. To used to key switches where if you turned it back to the left you would shut it down :D Makes pefect sense on the older models :rolleyes:
2,241
Not sure it works on all models, but it works great on my old B7100. An acquaintance with a B6100 got mad at me, saying that using this technique "burned out" his hour meter. Turns out he was just not turning the key all the way back to the "ON" position after "glowing" a second time- the electric meter doesn't run in the "OFF" position, but the engine does.:D
Tooljunkie
May 13, 2014
4,150
27
I think it starts very well. Mine at -12 with oil pan heater and a boost doesent take off that easy.
I put it back in the warm shed.
4,708
I think the l1501's have a longing to be back in warmer climates and start under protest when it's cold out :eek::p:D
Sparky2k
L2800hst
Jan 9, 2012
Belwood, Ontario
When I bought my L2800 5 yr ago, it had 210 hours on it. Not being up to speed fully on the Kubotas, I asked the dealer to install a block heater prior to delivery. He advised that one was not necessary. Upon voicing my skepticism, he offered to come out, and install a heater if it failed to start using the glow plugs at minus 20C within two years.
Minus 28 deg C last night, went out, 30 sec of heat, started right up.
I do believe the 0W40 synthetic makes a huge difference too.
Cheers,
Sparx
clippy
Thanks everyone for your input. Very happy to hear everyone thinks my tractor sounds great! We've not had such cold weather since I took that video. So all my starts since that have been even better.
I'll have to go find something else to worry about. :D
clippy
Have tried this out. But like I just said above it hasn't been as cold recently. Hopefully it stays that way. But your suggestion makes perfect sense to me. Thanks for the tip.
2,241
You're welcome Clippy, thanks for the acknowledgement!
Thanks Vic, it's nice to be corroborated by the experts!
