I have a third function valve switch on the loader joystick to open and close a grapple and angle a snow plow.
It's an expensive fragile switch. it either fell apart or a limb hit it and broke the switch cover.
There is a white cover on it, or it used to be on it. When it is depressed it lights up green and allows the other two switches to operate. Pushed again it goes off .
The switch still works but the white cover has broken off. I got a new switch because water and dirt will end up in the switch.
Pretty basic. Anyone know what holds it into it's housing on the joystick?
I was hoping when I got the new switch I could see what holds it.
The switch has plastic threads and a plastic ring on them that is more than finger tight. At $170 I don't want to break anything...
Thanks in advance.
John
Thanks in advance.
John
