Spending more quality time with the B2150. The steering wheel is lose at the top of the column. I found a couple threads that mention replacing the bushing below the wheel.
Their are two bushing below the wheel. One sits at the top of the steering column tube, on the outside of the tube, and is called a Shaft Cover. The other sits below the Shaft Cover, inside the tube, and is called a Bushing.
The Shaft Cover is thicker and seems like it could hold the wheel column better as it has more contact area with the steering column then the Bushing. The Bushing contact area with the steering column is very small, thin, and it looks more like a seal then a type of support bushing
Any one know for sure which to replace?
