B21 Electrical problem
Jimb21
B21
Apr 2, 2011
11
Paoli, Pa
I bought a used B21 TLB. It runs fine but the hourmeter, lights/flasher/horn, the tach and the fuel gauge do not work. There is an aftermarket hour meter and that works. I checked and replaced all the fuses and still nothing. Is there another fuse behind the dash that may be the problem? Also, I could not get the steering wheel off. I tapped the bottom of the wheel with a hammer to break the seal but I didn't want to damage it. Are there any tricks for that?
Jim
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Jim
Hi Jim welcome to the forum.the guys here are a helpful bunch and will be along.In the meantime there is a good search function which if you type in,steering wheel removal,you will get several hits which shoul help!:)
Dave
DsBota
B8200, G1800
Apr 13, 2010
281
Milton, Ontario, Canada
You'll need a steering wheel puller to remove the wheel. I had luck removing my wheel with a small hydraulic jack and chain. Sounds like you might have a ground problem with the electrical try running a jumper cable for a new ground. Did you test with a test light or multi meter to see if there was power coming to the gages and switch?
