B21 / Bevel spriral input of the differentiel / how to remove it
Harved
B21 tlb
Apr 3, 2024
Quebec
Hello new to this group. I removed the front drive shaft and I want to remove the spiral bevel at the input of the differential to replace the bearing. Need help how to do that !
Thanks
Sorry english is not my first first language...
4,274
Id this the correct drawing to look at ? If so ,for gear #080 , snap ring #100 needs to come off (it sit in groove near 050 line..)
ken erickson
Nov 21, 2010
1,021
1,596
Waupaca Wisconsin
Jay,
I think it is more likely the OP is dealing with the front axle and front differential from his description .
"I removed the front drive shaft and I want to remove the spiral bevel at the input of the differential to replace the bearing."
Warning*
Keep in mind this is the parts diagram for the US model. I have no idea if being in Quebec his B21 is the same or different. Part 200 is listed as
GEAR,BEVEL,ASSY 11-20T
6C040-97960
Harved
B21 tlb
Apr 3, 2024
Quebec
Jay,
Warning*
6C040-97960
Yes same as mine. I want to remove the part identifier number 200 and the bearing, shims . Do I have to remove both sides before ? Is there à link I can use to acces the manual shop ?
ken erickson
Nov 21, 2010
1,021
1,596
Waupaca Wisconsin
Hopefully someone with experience on your front axle will stop in and help you out.
I wanted to help clarify what component you are working on and or need help with.
I did check with Kubotabooks.com and did not see a WSM available as a free, (donations accepted) , downloadable manual. I know they are available at cost from Kubota parts suppliers such as 97897-12010 Coleman Equipment.
4,234
You likely can get Parts Diagrams like have been posted. Not a Shop Manual but help.
Try going to Kubota Canada's website, and search for parts and parts diagrams. Should be able to get them. As I'm south of the border, I can't get there to post a link for you. Maybe @GreensvilleJay can post the link for you.
