For a battery charger, I don't see much difference between brands and models aside from the maximum current available. Remember that this only indicates what it CAN provide, not what it will actually do, when measured with a proper amp meter.
Going back to old school devices, there was a simple 'float' system whereby the charge rate would drop off as the battery voltage came up close to charger voltage. There was a risk of 'overcharging' (boiling) the battery, so modern units have a bunch of messy electronics. End result is that if the battery is too low, you get no charge. Have to hook it up to a booster battery for a while (back to the old float system) for the flat battery to get enough charge to be recognized by the charger.
The way around that was to get a charger with a 'start' capability. This bypassed all the electronics, and allowed the full 10 or 50 or 100 amps to flow. Old style units with 'start' were also good because you could crank the engine in 'start' mode and get it going NOW, if that was important. 100 amps plus what the battery could provide was often enough.
Modern units with 'start' only allow full current for about 10 seconds then shut down to cool off to 3 minutes. I have one of these and dislike it very strongly. I bought an older technology unit a few months later, and while it is not so bad, it also clicks into 'overload' mode much faster than my unit of 10 years ago.
Whatever you buy, check into the electronic 'safety' features that may limit the flexibility of the unit.
