Any car gurus here?
dieseldude
136
Baltimore, MD
Any car mechanics here, looking for some possible casues of a thumping sound related to speed. I checked the usual stuff, ball joints, tie rods, all looks good. no odd driving conditions. no obvious defect in tires. any ideas
on a 2008 caravan.
4play
Roscommon Mi
Not a guru, but have experienced this sound with an out of balance wheel, or bad shock. Could be the wear bar on a tire, this happened on wife's car. Had this sound with a wheel bearing on my truck once also.
Good luck & keep us posted so we can learn too.
Thanks,
Gary.
4,051
I've replaced about 50 (really 6 or 7) wheel bearings on a 06 Chevy Uplander van. Usually a howl, but other funky sounds can happen, too.
Can you feel it in the steering wheel or anyplace else when it thumps?
4,051
A bad wheel bearing will not necessarily make it wander. The one's on our van I think are a bad design - been through a bunch of 'em.
Any odd tire wear? You say since they were put on.....
4,051
Hello, Check your tires real good. Had many with busted belts that's hard to see. Can be a long lump that's not real obvious!
Good point - I'm not a big fan of Good-Year tires due to belts.
Probably just my bad luck, but those Invicta tires they made years ago went bad on me due to belts. When they went on me, it would shimmy like a wheel out of balance.
They were OEM for many vehicles 25+ years ago.
dieseldude
136
Baltimore, MD
No, i dont feel it in the steering wheel, and I dont see any unusual wear, they look to be wearing fairly evenly. maybe it is jsut a busted belt and I just dont see the hump.
4,051
I'm no expert - just draw from experience.
I would suspect a belt or still, wheel bearing. If it does start to wander - that bearing is REALLY bad, and you don't want to go there.
Another that had me stumped a while back was sway bar link - but they bother on bumps.
Since you checked many suspects - I assume calipers, rotors are OK - no funny looking stuff there.
Does it seem front, back, or not sure?
dieseldude
136
Baltimore, MD
Calipers and rotors are good, just did a brake job recently. As for where its coming from, thats hard to say, it resonates through the van. seems a little stronger in the front. I did a crude check of the bearing when it started. no unusual play top to bottom or side to side.
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
Another thing to check out would be the cv joints. Blown needle bearings can cause a thump... and can be dangerous. How many miles on the caravan?
Is the thump getting worse or fairly constant?
Donystoy
Dec 10, 2013
504
165
Binbrook, Ontario
I bought two new Goodyear tires for the front of a car a couple of years ago and had lots of thumping especially when going around ramps. Dealer said there was nothing wrong with them until I interchanged front to back. He then replaced one at a time and of course it was the second one. The last Goodyear tires I plan to buy.
2,825
I might go along with steve here, and check the universal joints I have had them go south in the jeep and made a thumping sound that vibrated through the whole car
dieseldude
136
Baltimore, MD
Steve: I never gave CV's a thought. Last time I heard a bad cv it was more of a clicking sound, thanks for the tip.
Don: sorry to say these are good years.
Skeets: thats the weird part, there is no vibration. and doesent seems to be getting worse.
olthumpa
L275
May 25, 2011
1,501
Maine
almost sounds like a flat spot in the tire, been doing it since they were put on.
My money is on separating belts in the tires. Had it happen to me twice and that is how it presented itself to me. Seeing as it started when you had the tires put on just reinforces it.
I would have them rebalanced first and if that does not solve the problem insist on new tires.
Good luck.
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Have you tried swapping the tires front to rear/ rear to front, while keeping them on the same side?
It may help to see if it feels or sounds any different.
4,051
They won't necessarily be loose either - sometimes with a screwdriver to the bearing and your ear you can hear it making noise when you turn it.
After reading the posts you've attracted - I feel better that I wasn't the only guy with bad belts on G-Y tires - but mine were 20+ years ago.
Wish I was more help.
Please, when you do find it, let us know what the culprit was!!
dieseldude
136
Baltimore, MD
Havent had a chance to try anything yet, but will keep you all posted.
RCW, I have a set of wranglers on my truck, best tires I have ever owned, great wear, do well in snow and rail, fairly quiet and good mileage.
4,051
Yes - I had Wrangler AT/S on my last truck - 2007 Chevy.
I had good experience with them, too. Changed at 48k or so. I kept 2, 'cause they weren't that beat.
Not sure - but I think my '03 Chevy were Firestone/Bridgestone OEM. They worked great too, so I replaced the Wranglers on the '07 with them.
2013 Chevy came with same Wrangler AT/S tire - I'd be happy with the same wear.
dieseldude
136
Baltimore, MD
The set of Wrangler's I have on my '00 Ford now were suppose to be 60K mile tires. I'm pushing 90K on them, and am just now nearing the wear bar. if it wern't for the starting to slide in the rain and snow, I wouldn't be looking at all.
Speaking of Firestones, I had the OE Firestones on my '95 explorer, the one that were recalled because of supposed blowouts, They were good tires also. IMO, the only reason for the recall was people not keeping up on keeping their tire properly inflated.
