another tie rod end
chris989
L3450
Oct 5, 2016
35
boise
Hello all,
I am in the same boat as others and search some older threads.
Kubota wants ~$400 per side for my tie rod assembly. Both the inner and outer are toast on both sides so this is almost a grand to replace.
I have been searching catalogs for the inners 35080-4460. I can fab just about anything for the outers.
Does anyone know of a source for the straight 18mm inner joint or a link/idea how to safely fabricate something.
My 3450 is no cream puff so a little frankinfab wont hurt it.
thanks,
Chris
2,241
3,150
How many hours on your tractor?
What are all you guys that lose tie-rod-ends doing with your tractors that are killing the tie-rod-ends?
Are Kubota tie-rod-ends made of unobtanium which is very soft and untempered to cause so many failures?
Tie-rod-ends should be very durable.... the ones on cars/trucks last for 100k miles and a decade or more.
What’s with these...?
4,509
Not sure Geo. but they even have a shield to protect them. Folks have to be driving through deep thick brush piles!
4,223
maybe a lot of heavy loader,turning the wheels wear ??
With power steering it's easy to not 'feel' the stress turning the wheels without moving,something 'armstrong' sterring lets you KNOW .
as for replacements, I'd be searching the net for anything that 'fits the holes'....
orange crusher
BX 2680
Sep 30, 2017
356
480
ontario canada
Hey, you can work a D-4 Cat dozer just like a D-8...................................................for a while.
Works on the same principle as putting bigger springs on the rear of a 1/2 ton truck and make it a 3/4 ton.
