Another remote valve question
Fedup
208
58
Winchester
I still haven't gotten around to all the issues on the M125X. Today's question involves the detent valves used on this and probably other M series tractors as well. I'm assuming the pressure at which the valve cancels and returns to neutral is adjustable. If one adjusts that up, in the attempt to raise the working pressure before the valve cancels, is there a point where the valve won't cancel and start creating heat within the detent mechanism? Also would raising this pressure make the valve spool movement harder to operate?
5,288
No the detents are not adjustable.
So the rest of your questions become a mute point.
But just for the sake of an answer, no it wouldn't make it harder to operate or raise the heat enough to even notice.
Fedup
208
58
Winchester
If they are not adjustable, is there a spec for the pressure under which the loaded circuit can continuously operate before the valve should cancel?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
The remote valves are strange on a Kubota, or at least the ones I use they are. I use the #1 for my baler tailgate. At high idle I have to hold it to raise the gate. At about 1500 it will lock back at raise it on it's own and kick out when the gate tops out. At low idle it will lock but won't kick out when the gate it fully raised. #2 valve works as it should but when it's locked in float I have to jerk the crap out of it to disengage.
My friends 8540 the valves are very smooth but if you lock them in float position it has down pressure instead of float. Dealers told him that's how it's suppose to be but I call BS on that one. He actually runs a hyd powered sprayer with his in the float position.
SidecarFlip
Banned
548
Mine are the same Bulldog. Must be a M9 trait. Same on both the Os and the cab but the OS has the flow control segment between the 2 valve bodies, which I hardly ever use.
Fedup
208
58
Winchester
If it won't release at low idle I have to wonder if the system is reaching the required pressure? Do you hear the system relief valve and the engine grunt when the gate tops out?
Bulldog
Mar 30, 2010
5,440
73
Rocky Face, Georgia
It'll pull the engine down but most of the time it won't kick out at low idle. Been like that since new. As far as the hyd system goes everything works as it should. If anything it has to be feathered so to speak because it's almost to fast for some task.
