Wondering if anybody knew much about the grey-market B6000 I have that has the gear-driven tiller bolted up directly to the tractor where the PTO output normally would be? Is there a PTO assembly I can get that will bolt up and mesh with the gears? The previous owner built a "block-off plate" to use the 3pt hitch when he took off the tiller, but this doesn't allow any PTO-driven 3pt implements...
What is available out there? I know of the Hub City reverser, but this is only useful if you already have a PTO output shaft. Is there any kind of unit that will bolt up, mesh with my tractor's gears and spin a 6 spline PTO in the correct direction for use with common 3 pt implements?
