Air pressure on rear tire 3901
armydoc78
34
Jefferson, SC
I broke the stem off the tire and had to replace it and reseat the bead. However it doesn't say what the operating tire pressure should be. This is an R1 11.2-24. Any help would be great!
Doc
Racer X
GR2110 ~ 1948 Ford 8N ~ 1948 Adams Motor Grader ~ Kubota L260
Apr 28, 2017
121
The Great Pacific Northwet
Doc
I'd start with around 20lbs. Look at the tire. Does it look over or under inflated? Adjust the pressure to suit.
BAP
Dec 31, 2012
2,554
684
Your owners manual should say.
armydoc78
34
Jefferson, SC
The tire guy got it up to 40 lbs and then let some out. It's definitely over inflated compared to the other tire. My Farmall and John Deere run their tires at 15 lbs. Don't know where my owners manual is and going to buy a working pressure gauge since mine decided to quit today.
JasonW
241
104
Al
I lowered mine to 10 from 15 and got the ride softer. Makes a difference.:D
X2. I recently drained and swapped my rims around to get maximum track width. Filled with water and set to 14psi per manual. It's too much pressure so I'll have to lower it.
Here is the test I use, set the tractor on concrete or similar, take the implement off the tractor or lower the implement to the ground so all the weight is off the tractor, lower the air pressure until the entire tread on the bottom part of the tire is touching the ground. Check the pressure and let out probably 1psi more and it should be good to go. This is for maximum traction.
I recommend this for rear tires only. As most front tires, like mine with the loader, need more psi so they don't get pinch flats when you get the loader full of material.
Just noticed the manual says 36psi for the fronts, but on the sidewall they say max load at 52psi. I also recommend going by what the tire says on the sidewall over the owners manual, and that's for trucks, trailers, ATV's and more.
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I would check the air pressure in the other tire and start there, then Change both if desired.
Sent from my LGMS330 using Tapatalk
