Air filter bottom latch B7100
BobInOK
79
Catoosa, OK
I have two complete air filter assemblies from different generations of the B7100 and both have an issue with the bottom spring wire latch not latching properly. The top one on both seem fine, lock in with plenty of tension but the bottom seems like it isn't catching properly and hits the cover before it should.
Is this common or am I missing something?
SidecarFlip
Banned
548
Might be slightly bent. Had that issue on one of my M's. Took the latch apart and put it in a vise and added some curve to it. Problem solved. You need to take the latch apart to do that. I presume you have the wire latches like I do. You want the cover to be tight against the air cleaner body and hold the filters in alignment.
BobInOK
79
Catoosa, OK
Thanks for the reply...Found this picture on the net. It shows both clamps being long enough for the bend to go over the cap when latched. On the bottom latches of what I have neither one is long enough, the bend hits the cover and will not go over the cap.
Do I by some miracle have two canisters with the wrong latch on the bottom.
2,234
Weird. Maybe a pic of the latch that doesn't fit?
5,119
It's not the wrong latch, it's bent / stretched, you need to unbend / rebend it, look at the curve of the working one to see how to bend it.
BobInOK
79
Catoosa, OK
This is what I am dealing with. Weird that both bottom latches have the same problem, what are the odds... Think I see now where the loop that holds the latch is opened up further than the latch that works.
SidecarFlip
Banned
548
You are making it way more complex than it really is. Take the latch apart and put some more bend in the end. If it's correct, it will 'cam over' when secured.
5,119
You typing just to type?
That that's not the problem, the OP again has a handle on how to fix it properly. ;)
