4520B backhoe hoses
kbrothers
b2150 HST loader/hoe
Dec 1, 2013
84
Ebensburg,Pa
Does any one know where I can find the hose lenghts and sizes for the 4520B hoe on a Kubota B2150? Also could I just hook the new hose to the old and pull it or is that just a pipe dream All help appreciated Thanks
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
I'm guessing you are replacing hoses?
Just pull the old hose out with a strong draw wire attached, get new hose made up sames as old, then use the wire to pull the new one in?
Tooljunkie
May 13, 2014
4,150
30
Unless you are buying from dealer, there really isnt any listing for hydraulic hoses. Tie a wire to it and pull it through. Replace them all, doing one here and there as they fail is more costly in oil than replacing the whole works. Good time for oil change too.at least you have a little control where oil is spilled then. Blow out every new hose, one little wire fragment can trash a cylinder. That wire is hard,not only wil it trash a seal it will score the cylinder bore.
Tried to do a good thing and replaced hoses and a piece of debris got in and scored a perfectly good cylinder.
kubotasam
Apr 26, 2010
1,202
126
Alfred Maine
A Kubota 4520 backhoe is the same as a Woods BH650. The Woods manual shows the hose length. Send me a PM with your email address and I will send you a PDF file of the woods manual.
I do not think you will be able to pull the hoses through by connecting them together. It is very tight where the hoses all pass through the end of the boom.
But what the heck I have never tried so it might work.
