FOLLOW UP;
just got off the phone with them & didnt tell them anything about my tractor... just asked what it really took vs the 20-45hp stated.
they said if you dont have 18hp at the PTO... its not for you.
i said great! ive got a little more. THEN they asked me what tractor ..
told them 2601.. they said no problem running it at all.
but people will tell you anything so i searched around & found this fella on another forum & here is what he had to say about it.... & he just has a baby deere.. not a mighty Kubota!
Kennyrichmond Kennyrichmond is offline
New Member
Join DateJun 2014Posts18LocationPhiladelphia, PATractorDeere 1025R FILBERT
Default Re: Stump Grinder Woodland Mills WG24?
Quote Originally Posted by dickfoster View Post
I wonder how the Woodland Mills grinder is working out for Kenny. He said he ordered one and I figure he should have it by now.
It's worked out magnificently. Two stumps, one about 12" and the other 24" on the same residential property took about 1/2 hour, including extensive root systems. They were both overgrown ewe shrubs that had been about 35 or 40' high. I think the "chat" on the Woodmills site is a robot. You have to get them on the phone. There was a one week delay in the arrival of my grinder. It actually shipped to Philadelphia from a New York City warehouse. I'm not sure what might be going on with that.
So here's my impression: The grinder arrived on a steel pallet with 2 x 4" steel tube runners. The cardboard box was framed with steel angle and slats. I used it with a 1025 FILB with a Curtis Cab that has 18 hp at the rear PTO. It mounted right up without need for any cutting of the PTO shaft that came with the grinder. It is VERY beefy and looks expensive compared to the junk available for rent at HD. The 1025 Deere will raise it 15" from the grade. It is designed to be pulled through a stump. It has 34 brazed carbide chips that remained razor sharp after grinding through buried roots and stumps. The little Deere did get bogged down from time to time in damp clay, but with a hand on the lift while pulling the grinder through, it was easy to avoid a stall by raising it slightly. I left the rear window on the cab and it was good that I did because it chucked wood chips at me. I pulled the sway turn buckles super tight and have Pat's hooks on the draft arms, so to detach the grinder, I had to loosen up everything again. The Deere would sway on Turf Tires, but nothing scary. The lift height and short wheelbase made it very easy to maneuver the grinder over the stump inches at a time and by hard steering, the grinder moved laterally atshallow angles quite nicely. I would take this arrangement over the side to side hydraulic grinder any time. Sitting sideways in the seat (had to remove the arms from the swivel seat because of the cab), with a gentle left foot on the hydrostatic forward pedal, steering with a suicide knob, it was actually fun watching the chips fly. When the tractor was level, the grinder actually pulled itself through the stump at the rate it liked, with just a little assist here and there on the pedal. No need for extra hoses or hydraulics.
It exceeds my expectations and 18 hp PTO does drive it acceptably.
Ken
