3 point will not do anything
bruceatlam
B20, FEL, box blade, flail mower
Aug 20, 2009
410
Camarillo, California
I assume that it worked before you added oil? Where is it stuck --- all the way up or all the way down or in between?? Can you lift the arms by hand?? I assume you have a "rate of movement" valve under the seat. That's not completely close is it??
corky
Bennett, CO, USA
Yes, it was working. Don't know if it stopped working just before they noticed it was low on oil. It is stuck down and one can lift the arms manually.
