What unit of measuring would you guess is the play in the column? 1/16?Have any of you noticed a bit of play in the tilt column up and down?
Thanks,
Eric
Seems to move up and down about 1/4 to 3/8 of an inch...??? This is regardless of position you have it in...???What unit of measuring would you guess is the play in the column? 1/16?
I went and checked mine and noticed almost no movementHave any of you noticed a bit of play in the tilt column up and down?
Thanks,
Eric
Thanks for checking and reporting back...I will look to see if there is some hardware that needs tightening to aid in taking up the slack.I went and checked mine and noticed almost no movement
Look in section 6:It would be nice to see a parts manual on this for clarity...???
I have a copy of the service manual...It really doesn't show or mention the tilt assembly very well. I was looking or hoping for a "Parts" manual to better aid in this. Thanks for the help tough...
