21 hp 3cyl diesel; why so much smoke on start up?
donovjim
GR2110
Jul 13, 2015
Bedford, Nova Scotia, Canada
My first diesel. Gr2110 with 148 hours. Quite a bit of (at first) black and then white smoke on start up. Lasts about a minute or so until it warms up. I'm wondering if this is common at all times or is a tune up issue? Suggestions?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
The black smoke is unburned fuel being injected in the cylinders before it fires up. After it fires the white smoke is normal from a cold engine. Obviously since most diesels don't have spark plugs they ignite fuel from compression alone and cold temps will affect how long it takes for the white smoke to clear.
From what you describe it sounds like everything is normal
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
How long are you running the glow plugs before starting?
10-15 seconds?
Longer if it is colder.
Ray
5,130
If it's excessive might mean that it needs service, air filters play a role as do fuel filters.
Or it might be as serious as needing the injectors serviced or replaced.
macattackga
L2000DT
Feb 18, 2015
Fairfax
Try more glow plug time... use a watch... try 30 full sec...
CaveCreekRay
Jul 11, 2014
2,631
Cave Creek, AZ
I live in AZ and I still use my glow plug warming because it takes a load off the starter. Cranks right up almost instantaneously after as little as 5-10 seconds of "pre-heat." Cuts back on smoking on start-up as well.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Yup, even 90° outside, first start of the day always got a 10 count of glow before firing up. Works perfectly.
My unit has so few hours on it that it doesn't smoke at all at start, just one puff of dark exhaust then runs clean.
OBKubota
2014Gr2120,Gr2728Snowblower,Gck5GrassCatcher,agri-FabSpreader
Oct 21, 2014
205
Ontario
I have gr2120 and the manual say's start at half throttle and shut down on an idle as well as 5-10 seconds glow plug time depending on temperature.
Good luck !
donovjim
GR2110
Jul 13, 2015
I'll have to be honest and say I don't use glow at all....just roll it over. I'll have to do that... I was told by the seller it wasn't necessary but clearly he was wrong. (no wonder I had to change the air and fuel filters and even the waterpump).
I'm assuming that's just stage 2 on the key (I don't have a manual) for 30 seconds.
Thanks for the guidance. ...j
