2018 John Deere X390, 54" Mulching deck, pwr steering, pwr lift
RyanG
2019 Kubota BX2380, 60"mmm, FEL. 2018 JD X390, 54"mmm (for sale)
Sep 17, 2019
59
Fleetwood
SOLD
2018 X390, 22hp, Gas, Twin cylinder
-Factory warranty is good until May 2022 or 300hrs!!
-Purchased new from Deer Country Farm and Lawn May 2018
-Hours: 96
-Only been used to cut lawn and pull a small cart with leaves. Never seen snow etc.
-Always kept inside!
-54" Accel Deep Cut W/Factory Mulching kit + Mulch control
-Electric on dash mulch on/off control (great for tall grass areas to open the side discharge up then close again around the house right on the dash!)
-Hydro steering (no vibrations or bumps etc. felt through the steering wheel like you get with a manual steering tractor)
-Hydro deck lift (Also lifts any front mounted implements like a plow or snow blower)
-Hydrostatic drive with forward and reverse foot pedal operation. Very easy to drive and maneuver!
-Cruise control
-Hydro fluid and filter changed at 50hr as per the manual.
-Other info can be found on the John Deere website. Same as the 2019 X390 models.
Comes with:
-Side discharge deflector (I removed it since I use the mulching kit but can easily be installed again)
-Manual mulch control lever (replaces electric actuator if you ever want to remove that and return it back to manual control on the deck)
-Original owners manuals for the tractor and deck
-Spare key
-Delivery can be arranged as well if required.
Please let me know if you want to take a look or would like more pictures etc.
Located in the Kutztown/Fleetwood, PA area Zip: 19522
Never had an issue, Selling it due to acquiring more property and a compact tractor.
RyanG
Sep 17, 2019
59
Fleetwood
Re: 2018 John Deere X390, 54" Mulching deck, pwr steering, pwr lift, $4300
Price reduced!
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
Have you listed this on The Green Tractor forum? Most of us on this forum bleed orange.
RyanG
Sep 17, 2019
59
Fleetwood
Not yet, I figured it was worth a shot on here since it's a lawn tractor Vs compact tractor. But I'll have to make a post on there as well.
