By slow reverse i mean the bx seems sluggish in reverse at any rpm in high or low range , there is no visable obstructions , oil levels are good it just has no power in reverse
Glad you found the problem!Thanks for the info , figured out the problem there was a bolt on the rear of the linkage that was pressed into a fuel line!!! Way to close to being a major repair , if any one else has the same problem take a close look up above the hst filter where the linkage connects to the trans, it actually cut into the fuel line.
