First timer here.
The wife was mowing her back yard 9 hole PW course when our B2100 (1500 hrs) suddenly died with a half full tank of fuel. This is not the season for water in the system, so I started checking the fuel delivery system..
No leaks anywhere. Fuel filter changed. Filter housing and cup removed and cleaned, blown out, new O-ring installed, filter housing found to be without obstruction. Fuel flowed freely from tank to refill the cup in a rush.
The engine starts immediately on every try, but only runs for a second before dying. It will quickly restart, only to die again and again.
A new air filter is in place.
At this point, I am thinking an air/vacuum leak in the fuel system or obstruction further into the fuel delivery system. I notice there is some sort of diaphragm/ check valve? device next in line in the system after the filter housing. Could this be the culprit?
Any hints before I call the Orange Doctors? It has to be something very simple. The engine wants to run.
