Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 04-11-2011   #1
Johan42
New Member
Default B7100 rear PTO seal replacement
The PTO of my B7100 is leaking oil and I am trying to figure out what it takes to replace the back PTO seal. I cannot find much information on this, is there anyone who can explain?
Do I need to remove the backing plate (the one secured with the 6 bolts)? Or can I just remove the seal from the outside? and how? Do I first need to drain the transmission oil?
Any special instructions on how to move the new seal back in, eg. filling the ring with grease before installing?
Any advise is much appreciated
Johan42 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-11-2011   #2
JKP
1st Yr. Apprentice
Equipment: B7100D 219FEL
Default Re: B7100 rear PTO seal replacement
Johan42,
I am in the same boat, just got a new to me b7100dt and after three mows with the finish mower, here comes the fluid. I will be watching your thread for info as well.
Rgds,
J
JKP is offline   Reply With Quote
Old 04-12-2011   #3
cabu
4th Yr. Apprentice
cabu's Avatar
Equipment: Kuno B1-15 (B1502DT)
I had the same problem:
http://www.orangetractortalks.com/forums/showthread.php?t=1270
Actually you need to replace the seal from inside. But when I started the job I figured out, that the bearings where used up, the oil was dirty and had a lot of metall parts. And so I brought the tractor to a shop because they have all the spares.
Changing only the sealing is cheap...
carl
__________________
Kuno B1-15 w. Fronthydraulic+Lifter / Mulcher EF115 / Tiller RS1100 / 13HP WoodChipper / YardMan HE5150
cabu is offline   Reply With Quote
Old 04-12-2011   #4
Johan42
New Member
Carl, thanks for your quick reply.
I am still a bit confused though, particularly by a posting which I found today on another forum and which claims the seal can be removed from the outside without removing the PTO cover plate: http://www.tractorbynet.com/forums/k...-off-seal.html
I thought it would not harm to give this simple recipe a try. So drained the transmission oil and then removed the seal with a small screwdriver. Unfortunately it did not remove completely, as one can see on the last picture.
So not sure whether the reference above is incorrect, or whether I did something wrong.
Any more advice / experiences are very welcome!
Click image for larger version
ID:	3281   Click image for larger version
ID:	3282   Click image for larger version
Old 04-12-2011   #5
JKP
1st Yr. Apprentice
Johan42,
While I am still waiting on others to reply, I can tell yo that all you removed was the rubber part of the seal. The rusted circle around the rubber part is the main part of the seal. A new seal will consist of the metal ring with the rubber attached and a small spring looking circle in the rubber part. I am hoping someone will chime in with the answer about replacing from the back without removing the plate. I also saw the article you referenced but not sure if the seal will go over the PTO shaft from the back. Since you are trying it go ahead and remove the metal part and see if you can, you've already removed half.
Rgds,
J
Old 04-12-2011   #6
cabu
4th Yr. Apprentice
cabu's Avatar
After you have allready drained the oil you can also open the cover. It's no magic behind. You can take the gears out with no extra tools, just take them replace the seal and put the two axles back in place. Easy job!!
Have fun
carl
__________________
Old 04-12-2011   #7
JKP
1st Yr. Apprentice
Carl,
Thanks for the follow up, after the next mow I will give it a try.
Thanks,
J
Johan,
Looks like it is just as easy to remove the cover.
Good luck,
J
Old 04-14-2011   #8
Johan42
New Member
Ok, I removed the 6 bolts and opened the cover. This was actually pretty tough since the plate was glued to the transmission case. Anyway, after carefully hammering it finally came off without any damage, 1 hour later . Indeed no magic behind the cover .. all parts came out easily (Picture #1)
There was a small problem though. One of the ball bearings had a broken ball retainer (Picture #2) and pieces of metal were laying around in the oil. So went to the tractor shop, bought new bearings and replaced the old ones.
The PTO seal which I'd ordered had also arrived so now I could actually see the thing (Picture #3). The rubber seal indeed has an attached metal ring, as described by JKP (note that this is different from the pictures that some webshops show as the PTO seal).
Assembling everything was pretty easy. Pressed the new seal into the back plate. Inserted the PTO shaft (added some grease so the rubber does not immediately get damage). Moved the other shaft back in place. Installed a new gasket. Closed the back plate with the 6 bolds. Added new transmission oil. Etc ... Pictures #5
So ... what have I learned .... the PTO seal can actually be removed without opening the back cover. It is pretty simple: there are 2 notches in the circle on the back plate (the 2 indentations that are lined up horizontally). Put a small screwdriver behind the metal ring and the seal should come out .. Picture #4
As said above I went a different route, opened the case and knocked out the seal from the inside. But I do not see any reason why this cannot be done from the outside. BTW, the guy at the tractor shop confirmed .. just drive the front wheels of the tractor into a ditch (plenty of them here in Holland ) and remove the seal with a screwdriver.. no need to drain the transmission oil ... just a 5 minute job, he said.
But I am happy that I did open it and could replace the damaged bearing.
And certainly an interesting first exploration into the interior my new (1977) Kubota!
Name:	1 Shafts removed.jpg
ID:	3285   Click image for larger version
Name:	2 Broken ball retainer of bearing.jpg
ID:	3286   Click image for larger version
Name:	3 PTO seal.jpg
ID:	3290   Click image for larger version
Name:	4 Remove seal from outside.jpg
ID:	3291   Click image for larger version
Name:	5 Finished.jpg
Old 04-14-2011   #9
bruceatlam
3rd Yr. Apprentice
Equipment: B20, FEL, box blade, flail mower
Nice job! Thanks
bruceatlam is offline   Reply With Quote
Old 04-14-2011   #10
fj40dave
2nd Yr. Apprentice
fj40dave's Avatar
Equipment: L295DT
Nice job x2!
__________________
Pictures of the L295DT I rebuilt in 2010
http://s1095.photobucket.com/albums/...bota%20L295DT/
fj40dave is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
