I just called my local deal and they said all they sell in the magnetic block/oil pan heaters. Do these work? I wanted to put a regular block heater in my M7950dt cab but can't seem to find where it goes.
Do these work?
thanks Todd
The oil pan heat works fine, finding a spot that it can smoothly hook up to is another problem, and keeping it from getting knock off - unless it is a flat pad.
The real thing about those, they heat the oil, which is fine, but the engine still has to fire and run so the warm oil can get through the engine.......
the better answer is a water jacket (block) thus the warm water ALSO circulates through......then again warming the fuel helps too.....
andthing is better than nothing ...........
