Hoist Ring Tie Down?
TruckCo12
MX5400
Jul 23, 2021
I have a new MX5400 and have been thinking of ideas to make securing my tractor on the trailer easier, protect that nice new paint (I know it’s a tractor 🤷‍♂️), and I just like tinkering with stuff. I was thinking of picking up a pair of used hoist rings and placing one on each side of the front of the tractor where there is already a hole in the frame near the brush guard. Very similar to the location of the Ai2 tie down kit for the BX tractors. There is only have 1 hole tho and I don’t want to drill anymore so this seems like a solution (strength, swivel, single hole mount). I read a post somewhere with the idea but no further details. While they are usually ridiculously expensive new, you can get them used for not too terribly more than say a D-ring considering the strength/swivel factor.
-Any thoughts on this being a good or bad idea?
-What size would I need to loop 3/8 g70 chain through them?
-Better method to attach chain to them? Was thinking of keeping the chain with hook on it as opposed to adding a shackle or something just for the versatility of the chain when it’s not holding the tractor down but open to suggestions.
-Any other ideas all together?
2,223
On a BX not a M series but same thought.......
Loops were less than 10 bucks each.
One hole was there already - I drilled the other - grade 8 bolts
a 5/16 chain hook will go through and attach to the binding chain.
Straps also work well too ! I have used these hooks several times on road trips.
TruckCo12
MX5400
Jul 23, 2021
I wasn’t asking anything regarding the law when it comes to securing the tractor. What I was trying to avoid was drill a second hole for an attachment method that requires a second bolt when I can potentially add a method that’s potentially stronger and can use the a hole from the factory. If I drilled a second hole it would end up being right next to this one.
TruckCo12
MX5400
Jul 23, 2021
Straps also work well too ! I have used these hooks several times on road trips. View attachment 63557
That’s exactly what I am trying to accomplish! I was just trying to avoid drilling a hole and use the hoist ring instead.
KbotaL185DT
Kubota L185DT (sold),Kubota B7800, LA402, 5 foot Bush Hog Squealer
May 29, 2020
19
26
Rangeley, Maine
Use a heavy gauge angle iron and you can space your holes to match factory bolt holes. Sturdy and easy. You could always weld gussets on to it from additional strength.
RBA50
B2320, LA304 loader (B1658 QA), B2789 snowblower, RCK54-29B MMM, HF quick hitch
Apr 29, 2013
133
19
Goldendale, WA
I assume you are referring to solid cast type hoisting rings. If that is what you are wanting to use, you should be good. I have used those for lots of similar things. They are very strong. Just be sure to ones that are big enough (not the 1/4" variety!)
TruckCo12
MX5400
Jul 23, 2021
Yes those are the hoist rings I was referring to. However I ended up going with some swivel anchor (bolt style) instead. They have been shipped but I haven’t received them yet so can’t speak to how they work yet.
