I needed a little more room ( 9" )
Anvil HB
B2630 LX2610
Jul 29, 2020
14
10
Ocala Fl.
I gained 9" from the shop door with this little fab job. I will at some point move my welding table's around.
aaluck
Oct 9, 2019
966
820
Snowdoun, AL
Good idea. Plus you always know where it is.
dlsmith
BX2230, LA211
Nov 15, 2018
1,257
820
Goshen, IN
You have good taste in MIG welders.
Is that a Miller 211 on the bench?
5,541
ain't goin to bang your shins trying to get through there anymore either !!!!
I really,really HATE sleeves in receivers when not in use......
armylifer
Mar 26, 2013
2,102
852
Thurston County, WA
I don't know what those sleeves are supposed to accomplish. I have never seen a larger than 2" insert. My Chevy Silverado came with the factory tow package and they put one of those larger receivers on it with a sleeve to down size to a 2". Seems stupid to me if they are not making inserts larger than 2".
Anvil HB
B2630 LX2610
Jul 29, 2020
14
10
Ocala Fl.
I have had this receiver for some time... I have moved it 100 times in the shop, it was just under 11" be for I cut it..... My 2017 F-350 has an insert that can be removed when needed...
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
My Ram 2500 came with a 2 1/2 inch receiver. Commercial trucks (Dump, tow) usually have a 3 inch receiver. The receiver is rated to pull more than the truck. I have one seven 2 inch receivers and zero 2 1/2 inch receivers in the garage. I will be buying a bulletproof hitch in 2 1/2 inch for the Ram, and continue using a sleeve on the Ford.
