B1700. Trying to replace a hydraulic hose located at the side of the engine. It's fairly cold weather - around 5 F - and a tight location, can barely fit a small wrench, with maybe 40 degrees of movement.
The fitting is located just in front of the pedals, the shaft in the front right of the photo is for the brake pedal.
Any tips on loosening and applying enough pressure to move the fitting? Can I do it just by reaching in, or do I need to take apart more to get better access?
Thanks!
Thanks!
