Kubota L2501...direct injection or not?
troverman
Jun 9, 2015
1,188
268
NH
So I'm contemplating buying a new L2501. I know the engine is a 1.7L inline three, but does anyone know for certain if this engine is common-rail direct injection? Or just indirect? Does it have an electric lift pump?
Thanks in advance
sheepfarmer
Nov 14, 2014
4,444
662
MidMichigan
Direct injection does not necessarily imply common rail high pressure injection. The L2501 does not appear to be common rail, like the other L01 tractors which have dpf filters, but is direct inject.
4,433
Common rail or not, direct injection engines are much easier starting the IDI. Different design in heads make a huge difference!
SidecarFlip
Banned
548
I wasn't aware that Kubota made any pre-chamber engines honestly. Thought they were all direct injection. Far as lift pump goes, I suspect if it's common rail, then electric. If conventional injection, lift pump because a common rail engine needs fuel pressure before it starts to crank.
troverman
Jun 9, 2015
1,188
268
NH
I guess “direct injection” simply means no pre-combustion chamber. Could still be mechanical injection for all I know.
FYI...Duramax diesels were common rail but no lift pump, so it is not a requirement.
troverman
Jun 9, 2015
1,188
268
NH
Yeah, I’m pretty certain it’s not common rail. I have seen “electronic” direct injection terminology used in marketing materials though. The engine driven pump is the high pressure pump, not the lift pump. Lift pumps are normally electric. You can hear mine turn on in my MX when you turn the ignition to the glow position.
5,284
Yeah, I'm pretty certain it's not common rail.
Your right, No it's not
I have seen "electronic" direct injection terminology used in marketing materials though.
Not for the L2501, you will for the L3301, and L3901, about the only engine controls on the L2501 that are even electrical is the starter and fuel stop solenoid.
The lift pump and the injection pump are both fuel cam driven mechanical pumps
Simply not true, kubota has a ton of models with mechanical lift pumps.
You sure, they normally only turn on, in the on position.
The L2501 is as Blondie70 said:
Mechanical lift pump
Mechanical Injection pump
Mechanical Direct Injectors
No Common rail
No High pressure pre pump
No Electronics for the injection system.
No electric pumps
troverman
Jun 9, 2015
1,188
268
NH
Thanks NIW. I wasn’t aware these things used mechanical lift pumps. Does my B2920 use something like this? Or is it simply gravity feed?
The MX has auto glow plugs...which is the same as the “run” position. There is an audible pump whine.
5,284
B2820: Mechanical lift pump
None of the kubota's are gravity feed, they either have a mechanical lift pump, an electric fuel pump, or a combination of several types. ;)
