B2650 Grill Guard
Clover13
220
NJ
I've been doing some and plan on doing a lot more brush moving. I've seen the warnings against the potential damage to the stock grill and radiator. Unfortunately I'm not a welder, so I guess my options for adding a grill guard are to find one, or to learn to weld, or see if there is an aftermarket seller of an already beefed up grill guard?
sheepfarmer
Nov 14, 2014
4,444
661
MidMichigan
I too would like a better grill guard when I have my pallet forks on to carry branches, and some day will find someone to weld up a nice one. In the meantime in case of emergency, several layers of the plastic construction fencing can be wrapped around the existing brush guard and tied with baling twine :D
Clover13
220
NJ
Hah, yes!!! Throw in a little duct tape somewhere and you have this guy...
bird dogger
Vendor Member
Feb 24, 2019
1,573
1,423
North Dakota
Hi Clover13. I too have a B2650 and will be doing a lot of brush clean up work this spring and summer. I'm just finishing up my grill guard mod now. Just have the repainting to do after welding on the guard material. I'll post some pics in a couple of days when the painting is done. I think it's a project you could easily do as a first time welder if you have access to one. I picked up a small left over piece of expanded metal from the local machine shop for $12. With a little clamping here and there along with some spot welds to hold things in place is all it takes. Of course you have to grind/sand the paint off the front edges of the framework before welding. :D The expanded metal is real easy to cut to shape with a little side grinder and even neater with a cutoff wheel installed in the grinder. Sheepfarmers idea is an excellent emergency or short time fix until you decide what route you'd like to take!! Sometimes, short term fixes can last for years, too.
David
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
215
It's amazing to me that Kubota left exposed critical components in such a vulnerable environment on the front of the tractor. I purchased a perforated steel plate 3/16" thick with about 1/4" diameter holes. I'm not a welder either but I'm going to find a buddy to weld it in. I really need to learn how to do stuff like this myself. I can afford the equipment and just need to watch Youtube and get experienced friends over to show me how to use it. It doesn't have to be pretty, just prettier than a hole through the plastic grill and radiator.
tempforce
B2650HSDC
Jun 23, 2012
389
bastrop, tx
i have the factory grill guard, i can verify that it is in need of modification. as i have a good sized split in my grill. due to a stick punching a hole in it... my plans are to spend some time this week and weld some expanded steel to the front of the grill guard. yes it will make opening the hood more difficult... maybe i can figure a different way to lift the hood, other than reaching through the grill guard...
bird dogger
Vendor Member
Feb 24, 2019
1,573
1,423
North Dakota
I just posted my pics for you of my grill guard in a new thread. Take a look and see what you think. It was a lot easier to do than I had anticipated!! Especially if you have or have access to a mig welder. If you don't have much experience welding....watching some youtube videos on the subject and first practicing on some scrap metal will get you where you need to be for this project in short time.
Plus, a file or some grinding can easily correct some errors or unsightly welds. And fresh paint makes everything look good. :D Your new grille guard would be a great first project!!
David
