So yesterday, i spent the evening into the late night, removing broken exhaust manifold bolts from my 2006 GMC Sierra with the 6.0 gasser.
I used my Hobart Handler 140 MIG with flux core wire and welded nuts to the remaining broken bolts that were still in the heads. Some were easy as the bolt was protruding like a stud, and some were recessed so i had to make a jig to hold the nuts in position so i could weld, and build them out into the nut. Took some work but got it all back together and only broke one spark plug wire.
Anyway, I got to pondering why when i would weld the steel nuts to the steel bolts, and get them glowing red/orange/yellow hot, does it not effect the aluminum head in anyway? Obviously i never got the nuts or studs hot enough to melt but surely the temp was hovering close to the melting point of aluminum.
Just something i was wondering.
Still gotta do the passenger side. Two broken manifold bolts over there.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
