M4500 Power Beyond
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
564
169
Herald Calif.
That is the best place to tap Into the hydraulics. Put to 90s on the steel line Run one end to the valve return the oil back to the other one. Good luck. Lance
5,123
Just for clarity, you do not tap into the larger line, that is the suction line, you will just break the smaller line.
Also because your using a valve ahead of the factory relief valve you need a function valve with a relief valve in it, or you can blow the seals out of the pump.
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
ɹǝpunuʍop
If you are tapping the high pressure line directly from the pump, ensure your valve block has a pressure relief valve built in and ideally line to tank, otherwise you may deadhead your pump.
mcnzder
M4500
Jul 28, 2015
11
Cottage Grove, Oregon, USA
Thank you for your fast replies. Looks Like I have 2 options
1: break the pressure line, run a hose to the new control valve (with pressure relief) then out of the new control valve back to the original connection point.
So basically putting the new control in series with the original system. (this seems the neatest and easiest and what I'd prefer)
2: break the pressure line with a "T" leaving the original line connected and branching off to the new controller and dumping the output of the new controller back into the reservoir(So happens I have a spare plug into the reservoir doing nothing).
Am I understanding this correctly?
007kubotaguy
Dec 23, 2012
564
169
Herald Calif.
Hello
#1 will work. #2 with T not work. With a T the oil will always take the path of least resistance.
Good Luck Lance
5,123
Only option 1 will work, you never want to tee a kubota system it won't work as it's an open system and you won't get pressure for the valve to work. ;)
EDIT: 007 beat me to it: :)
WFM
L3800
Apr 5, 2013
1,191
502
Porter Maine
That's a nice looking unit. But is it a snowblower or tiller ? Or something else ?
mcnzder
M4500
Jul 28, 2015
11
Yes a Flail mower that swings out to the right beyond the tractor. The head also lowers down to 60 degrees for mowing road side banks and can be swung up to 90 degrees to allow trimming or hedges etc.
rjcorazza
Mar 9, 2016
778
22
Hyattstown, MD
This type of flail is on my short list. What brand is it?
