Not an expert, but I had the same problem. The concrete trucks were the worst. Each truck got stuck and had to be pulled out by the next. The last one need two other concrete trucks to pull it out. However, between those, skytrac, lift truck, deliveries, and getting power run to the barn my whole yard was destroyed (not unexpected).
I used a box blade and FEL to get everything filled in, and used the rippers (scarifiers) to loosen everything up. But in the end, you will need something to smooth things out (fence or bed springs as wolfman said). I ended up ripping up about 2 acres of lawn and it took a lot of time with a 6' box blade. I still think that was the right tool to get things leveled and smooth and it now works good as ballast. Plus I have a gravel drive to use it on for leveling and pulling snow away from the house.
Now for the "but". In the end, the lawn needed more work and smoothing. I could have gotten by, but I wanted it smoother to save my back mowing and I wanted to get rid of more weeds. Last week I got a 6' rototiller. Wow... does that thing make it easy. So much less time to tear up the yard this time. I already had a small roller that I could use behind the mower to repack the soil. With the tiller you will need to roll it if you for down deep to reseed.
Just my experience.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Just my experience.
