The arms will fall down after the engine is off for some time. When the engine starts the arms come full up. The lever on the control valve has no effect. Lots of force will not move the arms down.
FEL works fine...maybe a little slow. I noticed that the return from the FEL valve is plumbed to the port on the transmission under the seat (bypasses the distribution valve). I will correct this at some future time in the event the FEL is removed.
I have tried disconnecting the feedback arm and moving it along with the lever, but no change. When the lever is moved to full up position, it puts a load on the tractor so I immediately moved it to the down position. No sounds from the control valve. This valve has been worked on previously, but not by me, so I don't know what was done.
Are there any tests that I should try before I start to remove and open the control valve? I do not know what to look for after I dis-assemble the valve.
Need a lot of help here, please.
It is a B8200HST....I review 20 pages related to 3pt but no good help.
