B7100 rear axle hubs
2,171
I have read quite a bit on the various old style rear axle hub fixes. I see they sell replacement hubs for $140-$160 each, which is a little steep for my blood.
I ran across these on ebay...https://www.ebay.com/itm/Wheel-Hub-...d=122723261259&_trksid=p2045573.c100033.m2042
Anyone try these replacement hubs? Do you think it is a good replacement option?
Mike,
that seems like a hellva deal!!! Great find!
Question - the old style pinched the axle with a tight grip on 6 sides....more or less.
https://www.ebay.com/itm/Rear-Hub-f...d=401422238603&_trksid=p2047675.c100009.m1982
http://www.orangetractortalks.com/forums/attachment.php?attachmentid=17822&d=1440300419
I wonder if that two bolt style would have the same effect. You cannot see inside the hexagon in the picture, wonder if there is a "plate" that squeezes on the axle - or is it JUST the two bolt faces pinching?
Either way - be worth the price to try it!
procraftmike
1977 B7100DT w/B219 FEL
Jan 27, 2016
277
10
Neenah, WI
I have found some other pics as well. It appears it is just the 2 bolts that contact the axle.
MikeyA
2016 B2650 FEL and 60"mmm,1998 B2400 MMM FEL(sold!) BB 4ft BRUSH HOG
Mar 6, 2010
150
West Central Illinois
I found that the spring was bottoming out on the tension bolt on my 1994 B7100, and that was allowing hub to not tighten down sufficiently. I trimmed one coil off of spring on each hub, and never had an issue sgain.
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
Designers of industrial machines that use sprockets and pullies have long known a second set screw at 45 deg from the first is less likely to work loose vs a single set screw. Of course the collet style hub is far superior to both! Jeff
