My Kubota B 6100 D did not come with a dyno. Was wondering what parts I needed and if there is a specific way to install it. Thanks for the help
You sure it does not look like this??? THIS IS The dyno! No water pump!I am sure there is a belt but no dyno
There is a belt tensioner pully. The belt runs the crank, waterpump and tensioner.
Okay so apparently it's not hooked up and I can't tell what goes to what. Are there any suggestions to a wiring diagram so I can hook this back up and see if it is working?
Depends on how fast it spinsSo all I need now is a new battery. what kink of output should I get with the volt meter?
