Anybody Modify Aftermarket Cylinder for B219 Loader ?
Temblor
B7100 B219
Mar 2, 2016
20
Seattle
I have seen a couple posts about a Maxim Cylinder.. or this Dalton http://www.daltonhydraulic.com/dalton-welded-tube-cylinder-2-bore-x-18-stroke for $160 delivered. but no followup on modifications?
It seems the brackets need to be cut down a little to 1-7/8" ?
And maybe use a pipe for a shim so the 5/8" Kubota pins will work ?
Any suggestions would be appreciated, as my rod has heavy pitting and appears it is bent.
If I do not hear from someone who has modified theirs to fit, I may end up spending $200 + Seals on having new rod for mine. (However I do not know the condition of the barrel housing yet)
This opposed to spending $150-$160 on the Maxim or Dalton Cylinder HOPING I can modify it and get it to work.
5,150
Temblor
B7100 B219
Mar 2, 2016
20
Seattle
I gave you other options in other thread.
http://www.orangetractortalks.com/forums/showpost.php?p=175153&postcount=53
Altering a hydraulic cylinder is a BAD idea. ;)
If I remember correctly the cylinders on the B219 are only 1 1/4 or 1 1/2 bore, jumping up to a 2 in is going to slow it way down!
And why try and stuff a larger cylinder in there?
Thanks, does anyone have specs on that Kubota cylinder?
Not sure of bore? I thought it was 2" Bore 1-1/4" rod per another post..
but, my measurements are as follows
Barell is 2.380 so is this 1-1/2 or 2" bore?
Rod is 1.125
IDK how to measure stroke exactly, but measuring from center of tube on rod end, to center of tube on barrel end (where the pin goes through) when cylinder is 28-1/4" extended compressed is 17-1/4" so does that mean it is 11" stroke ?
So would this Maxim cylinder be closest? http://www.baileyhydraulics.com/Maxim-3000-PSI-Welded-Crosstubes_11
But this has a 1.250 rod while mine is 1.125
Modifying would be cutting/shortening the brackets by 1/4-1/2" on each side. to fit 1-7/8" on kubota Loader. and using shims to accommodate 5/8" shims.
Would be a huge issue on a compact tractor that only lifts 400-500 lbs.?
has anyone modified aftermarket cylinder for B219 FEL?
4,398
Temblor, I think you could eliminate a lot of grief if you'd take your existing cylinder to a local hydraulic repair shop. Get a quote for a complete rebuild. If you don't want to go that route, get the repair parts from the shop and rebuilt it yourself.
If they(or you) have the cyl. disassembled they can tell you the condition of the parts you're concerned about, and give you a cost on those also.
Then you know you have the correct volume/speed.
Temblor
B7100 B219
Mar 2, 2016
20
Seattle
Thanks, I am aware of that.. it is $300-$400 range for a new rod installed.
But my post is to find someone who has utilized an aftermarket one.
There are others interested in these as well.
Thanks tho..
seanbarr
B7100DT (sold) - Branson 3520H
Feb 1, 2013
384
Deer Park, WA
I gave up looking for a replacement cylinder, bought two with similar dimensions (same bore though) and repositioned the brackets. :)
Granted, I did it to accommodate a replacement bucket.
Temblor
B7100 B219
Mar 2, 2016
20
Seattle
Thanks for sharing that, I ended up ordering 15" of 1-1/8" Chrome steel Rod from supplier in Texas http://www.alloysandcomponents.com/chromerod.htm
Cost about $30.00 shipped.. took it to machine shop in Everett WA (Guy runs at his house) he charged me $100 labor to duplicate the bent rod..
He even assembled it with seals for me and tested Cylinder ( I was planning on doing latter part myself)
Thanks for any help here... and thanks for a cool machine shop! Works great!
Cylinder/Hydraulic rebuild shops wanted like $300 minimum to do the same job.. I know they need to make a living.. but what can I say, this is a 80s Garden tractor.. I can not afford to spend $300+ for every cylinder rebuild.
seanbarr
Feb 1, 2013
384
Deer Park, WA
Post pics when completed! And what machine shop are you referring to?
sinisterbiker
US
Actually I'm just starting to do this now , i screwed one tilt cylinder up , can't find a exact replacement at all and they told me it would cost as much to fix it as it would be to make a new one . I'll post pics on my progress.
Sent from my SM-G930T using Tapatalk
seanbarr
Feb 1, 2013
384
Deer Park, WA
Hold up, are you needing a replacement for one of the bucket cylinders? I have one.
sinisterbiker
US
Rod is 1.125
They are 2"bore , 1 1/4" rod
seanbarr
Feb 1, 2013
384
Deer Park, WA
Surprised that sinisterbiker hasn’t responded. The stroke length is unique.
seanbarr
Feb 1, 2013
384
Deer Park, WA
I understand, I mentioned that I HAVE an exact replacement available.
It came from my loader when one went bad and I replaced both & kept the other.
Anyone that needs one is welcome to it instead of taking the long route of customizing one, etc.
2,240
I would be interested in that as a spare. Maybe PM me with the details.
2,240
OOOPS! Forgot to add "If sinisterbiker isn't interested."
A case of fingers typing ahead of brain.:eek:
seanbarr
Feb 1, 2013
384
Deer Park, WA
Certainly. It’s up for grabs. Just pay shipping and some extra so I can donate to my local nonprofit organization, NEXUS of Spokane. :)
2,240
I guess we'll give it a few days to see if he speaks up.:)
