coachgeo
On my L225 if I sit a while with engine running; hopping off to remove something in the way for example, it wont go back in gear... almost like the clutch is not engaged (but is). Same for PTO lever. If I turn off the tractor and put in gear or PTO, restart and drive on then it will switch gears fine after that with no grinding.
Any thoughts?
Any thoughts?
