WTB: Pto reverser for Kubota b6000
BX-25D w/ Filled Rears,2" Spacers,PTB. Under Armor, 90'-90'-92'-B7100HST's
506
that's a tough one to locate .......... if you do - expect $500 or more for it
amsrn13
b6000
May 12, 2021
9
ct
Price doesn’t bother me, I’m thinking about making one as I have a Bridgeport and lathe and access to Cnc equipment. I’d obviously rather purchase one though
kubotafreak
Sep 20, 2018
401
Arkansas, US
I have not done the research on this at all, so ignore my ignorance.
Is there not a way to acquire a internal idler, or remove an internal idler to swap the direction? I cant imagine the cases being that different. I would think the manufacturer would add/remove this component to get the rotation based on destination country.
They do seem available if your wanting the external cassette.
amsrn13
b6000
May 12, 2021
9
ct
No, I did read some guys swapping out the internals from a 7100?
amsrn13
b6000
May 12, 2021
9
ct
That would be the ideal route. 7100 are very prevalent.
I found a company that makes a reverser for 800 shipped. So the question becomes , is it cheaper to buy all the parts from the 7100 or just buy the reverser . I guess you also need to factor in the time required to swap everything over
kubotafreak
Sep 20, 2018
401
Arkansas, US
I just studied the parts breakout from both of these. The rear differential case of the b7100 has the reverser build into the back cover of it. It literally reverses rotation at the back cover with the output being higher. Your b6000 does not have a provision on the rear of the case for this taller cover and spur gears. So with this said you would have to swap the whole rear differential as an assembly.
dvanpelt
B6000
Jan 4, 2021
10
Yakima WA
If you need one to study let me know. I am getting close to bolting mine up but am not in any hurry to do so. If you wanted one to do some reverse engineering off of I can help you.
Daniel
amsrn13
b6000
May 12, 2021
9
ct
Daniel
What does something like this cost ? The entire rear assembly that is ?
kubotafreak
Sep 20, 2018
401
Arkansas, US
Would be best to source out a salvage unit. I almost bought one for parts the other day. Whole 7100 bad engine for 500. B6100 housing should work as well.
dvanpelt
B6000
Jan 4, 2021
10
Yakima WA
Sorry for the confusion! I have a Hub City reverser that I am about to bolt up that could be replicated fairly easily with the right equipment/ability. If you decide to build your own you can use this one for a pattern.
