Wood Splitter Hydraulic Plug Question
Trail
BX2360, FEL, 60" Deck, Rear Blade
Dec 11, 2016
69
Wisconsin
Brought a used wood splitter home. Noticed when I got it back some hydraulic oil had leaked from the plug. It was a long and bouncy ride, and won’t be normal.
Should I be concerned about this? I thought this system should be pretty sealed for pressure?
I would have thought that a metal bolt would not be a good choice for a plug, but I notice this on other models.
I don’t have much experience with splitters.
6,564
That hole in the side is a breather for your hyd. tank. Just check you hyd fluid level when the machine is set up for use. Should be fine.
8,702
It can't be a sealed system, thermal expansion of the fluid while working would explode the tank! ;)
Trail
Dec 11, 2016
69
Wisconsin
Ahhhhh...that makes sense. Thank you both for answering!
